1965 water pump pulley - NCRS Discussion Boards
  • Rocco C.
    Infrequent User
    • January 8, 2014
    • 25
    While waiting on a carb rebuild to come back i decided to change my belts and explore a bit. I removed my fan and pulley, inspected the pulley for part number (found none). After install i checked the tension in the belts and grabbed a hold of the double grooved pulley. I noticed their is approximately 1/16 of play, enough to concern me. Would this be a tell tale sign of the water pump starting to fail?
    • 43258
    Re: 1965 water pump pulley
    Rocco------
    It's hard to say as there is a very slight amount of play in a good waterpump bearing. However, I'd base a decision more on how many miles are on the pump. If it's in the 50,000 mile range, I'd say your best plan is to rebuild or replace the pump. Also, if the car has sat for a very long time, that's another factor I'd use in my decision regardless of how many miles are on the pump.
    • Rocco C.
      Infrequent User
      • January 8, 2014
      • 25
      Thanks joe. The engine was rebuilt freshened up 4-7 years ago but have no way of telling if the water pump was rebuilt at that time or not
      • Domenic T.
        • January 29, 2010
        • 2452
        Rocco,
        Advise is all good but check tightenes of all bolts/screws on pulley. Yes that's a sign of a water pump failure. The water pump shaft will move if the bearings are bad.
        Dom
