1960 Front Crossmember - NCRS Discussion Boards
  • Stephen S.
    Infrequent User
    • August 6, 2014
    • 10
    I'm rebuilding the front suspension on my 1960 and have a question about a bracket that is welded on the top of the front crossmember, shown in the photos attached. I have reviewed past posts, looked at a number of front-end chassis photos and rebuild articles as well as the assembly and service manuals, but I haven't seen a similar bracket. It's 3 3/4 inches wide by 1 3/4 inches tall and has two threaded studs welded to it, facing forward. Does anyone have an idea as to what the bracket was for, maybe for an oil cooler? Nothing was mounted to it, I have owned the car since the late seventies. Should I simply cut it off and grind the area smooth?Thanks for any input you may have.Steve S.
  • Thomas H.
    • August 31, 2005
    • 1060
    Re: 1960 Front Crossmember
    If you can figure out what the hole in your rad support is for, then you will probably figure out what this bracket is for...............
    My 60 has no such bracket.
    Tom
    2007 Z06, Lemans Blue
    • Keith R.
      • August 31, 2001
      • 660
      Strange - must have been to attach some after-market radiator. You should cut it off and make the area smooth provided that it is a Corvette crossmember and not a passenger crossmember.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      2013 427 Convertible
      Shade tree mechanic and
      B-52 pilot extraordinaire
