Did all drive shafts have balance weights ? My 65 does not have any weights and does not show any signs of having one . It appears to be the original . Is there a way to check the balance without sending it out ?
65 drive shaft balance
Re: 65 drive shaft balance
Unless you find a special/old-school driveshaft shop, the weights used are different than back in the day. Fortunately, they almost cannot be seen.
Larry- Top
Bill,
I would imagine a shaft could be within spec with out any weight welded on. Odd or rare but possible. The weights are projection welded in place so if one "fell off" it would be difficult to tell with any weathering from normal use.- Top
Bill------
If you have the driveshaft out of the car and, especially, if you replace the u-joints, I highly recommend having the driveshaft assembly professionally balanced. Usually, this is not really all that expensive.
If it's in the car now and you're not having any symptoms of driveshaft imbalance, I would not bother to remove it from the car.
Can a driveshaft found to be without weights be properly balanced? Absolutely yes.In Appreciation of John Hinckley- Top
