frame vin numbers. - NCRS Discussion Boards
frame vin numbers.
  • Robert B.
    • March 1, 1992
    • 265
    frame vin numbers.
    When I took the body off the frame I could only make out a few numbers on the frame. Is there any reason I should stamp the numbers back on the frame before I put the body back on ??
    • 43246
    Re: frame vin numbers.
    Robert------
    Have you cleaned the area of the stampings thoroughly? Are the digits you can see consistent with the car's VIN? I'd be surprised if there was not at least some vestige of the complete stamping present.
    Also, there should be TWO stampings. One is in the rear kick-up area approximately in line with the rear spindle. This is the one that can be seen, albeit with some difficulty, with the body on the frame. The other is approximately in line with the seats and cannot be seen with the body on the frame.
    In any event, I would not recommend any re-stamping. You might just make something that's legit appear illegit.
    • Ray G.
      • May 31, 1986
      • 1189
      Hello Bob;
      Maybe take high quality pictures of what is legible.
      my .02
      Ray
      I hope you dance
