71 Small Block Air Filter - NCRS Discussion Boards
  • Seth G.
    • March 1, 1987
    • 116
    The air filter application for my base 71 calls for an AC 329 CW and NOS ones are difficult to find. Does anyone know if an AC 329 C would fit and what the difference between it and the CW would be? Thnaks
    • 43273
    Re: 71 Small Block Air Filter
    Seth------
    The AC 329 C will work perfectly. In fact, it's the one that GM has specified for your application for over 25 years. In my opinion, it's absolutely foolish to spend BIG $$$$ for an NOS original air filter element---absolutely foolish.
    I've forgotten what the difference is between "C" suffix and "CW" suffix but it's really moot in this case anyway.
      • 15631
      The W = oil wetted
      Once rosin paper became available there was no longer a need for the air filter paper to be coated in oil to catch the dirt particles.
        • 43273
        The W = oil wetted
        Terry------
        That's kind of what I vaguely recalled. too. However, I didn't dare say that for fear that someone would then ask why the 65-72 open element, AC 212CW still uses the "CW" suffix even though it has not been an oil-wetted filter in over 25 years. I don't have an answer for that.
          • 15631
          Terry------
          Nor do I Joe. The ACDelco filter catalogs have not shown the "W=wetted" listing in their definitions list since the early 1970s, and I don't believe any of their filters have been wetted since that time frame, but they continue (or more accurately: someone continues) to produce the AC 212 CW marked filters to this day.
          • Jim T.
            • March 1, 1993
            • 5351
            Terry do you have a supply of the real AC Delco AC 212 CW for your LT1?
            • Seth G.
              • March 1, 1987
              • 116
              I have one. Both box and filter are in excellent condition.
              • Seth G.
                • March 1, 1987
                • 116
                Thanks Joe -
                I understand from a functionality standpoint, it would be foolish to pay the premium for a NOS filter. That said, I want one to compliment my NOS Oil Filter as I enjoy collecting these parts. Thank you for the information as you are always helpful and I appreciate it.
                • Seth G.
                  • March 1, 1987
                  • 116
                  • David L.
                    • July 31, 1980
                    • 3310
                    For what's worth my Feb. 1977 AC filter catalog lists the following:
                    GM #6483645 = AC # A329C (H = 2 15/32", OD = 12", ID = 9 53/64")
                    GM # 6423921 = AC # A212CW (H = 3", OD = 13 15/16", ID = 11 5/8")
                    GM #6421746 = AC # A212CW
                    My 1970 Chevrolet Parts Catalog (Jan. 1970) lists the following in Gr. 3.410:
                    70 Camaro w/4BC (350)(exc. SHP).......6483645.......4.95..........ELEMENT (wetted paper)(w/6484674-5242).............
                    The 6421746 element does not have a description.
                    What is the difference between the 6423921 and 6421746 elements? Both are A212CW elements.
                    In the photo below of two NOS A329C elements:
                    1987 version on left, May 1974 on right.
                    Dave
                      • 15631
                      I have a supply of AC Delco air filters marked AC 212CW from many different eras. I think the problem enters in defining the era of each of them. There have been many threads on this subject and opinions are all over the place. If only I had photographed or retained the original; but alas it went into the garbage very soon after I got the car.
                      • Dave S.
                        • August 31, 1992
                        • 2930
                        Thanks Joe -
                        Seth,
                        I wanted an early original AC 329 CW for the same reasons. It took me quite awhile to find a real one from the early 1970's era but finally did. I've chased many parts in my day but these early AC 329's are tough to come by.
