Re: 427 foam in valve covers
Problem found, I think!!! Sealed the rocker studs and pressured the system. Leaking has stopped. Will put oil back in the motor and run, hopefully this will fix the problem. For info, the heads are 077 and have thread inserts in all the holes. All but 2 stud holes go thru to the water jacket so they definitely need sealed. The person who put them together did seal them with blue permatex but did not do a good job. You have to be sure to get the sealant inside the tapped hole so the thread insert is sealed as well, I don't think you can just put sealant on the bolt and expect it to seal. I put the sealer in the hole as well as on the bolt.
