Help to fix - NCRS Discussion Boards
Help to fix
+ More Options
Posts
  • Michel R.
    • August 19, 2014
    • 22
    Help to fix
    Hi, i'm a new french member. I've got a vette58 last winter from the US... I don't know how to fix fresh air hose bracket and clam (corr) on my vette... Is somebody can send me pictures to make me understand...It'll be super...!!! thank's. Best regards. Michel
  • John F.
    • March 23, 2008
    • 2417
    Re: Help to fix
    Michel, Is this what you are looking for? Welcome aboard by the way! This picture is off of a 62.
    • Michel R.
      • August 19, 2014
      • 22
      Re: Help to fix
      Hi John, thank's for the picture. Do u have one of the 4 screws to make me understand better. Best regards. Michel
      • John F.
        • March 23, 2008
        • 2417
        Re: Help to fix
        This is the best I could get.
        • Gary C.
          Administrator
          • October 1, 1982
          • 17773
          Re: Help to fix
          Michel,
          Are you referring to the screw that holds the clamp to the fiberglass inner fender?
          If so, the screws that hold the wiring clips and the fresh air hose clamp are part # 273446, which is a #10 Phillips Pan Head self tapping screw .5 inch long
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Michel R.
            • August 19, 2014
            • 22
            Re: Help to fix
            Thank's Gary... Perfect ! Best regards. Michel
            • Michel R.
              • August 19, 2014
              • 22
              Re: Help to fix
              Thank's John, that's perfect and help me a lot. Michel
              • Philip P.
                • February 28, 2011
                • 558
                Re: Help to fix
                John, is the tie on he hoses (picture 3) to hold them away from the belt?
                Phil
                • John F.
                  • March 23, 2008
                  • 2417
                  Re: Help to fix
                  Not sure if correct, but I use it on this car.
