Quick question. 1980 Corvette. - NCRS Discussion Boards
  • Don I.
    • July 20, 2014
    • 34
    1980 Corvette. 350 engine with automatic. All original. Can someone tell what my RPM' s should be at 50 miles per hour? Thanks, Don.
  • Leif A.
    • August 31, 1997
    • 3627
    Re: Quick question. 1980 Corvette.
    What's your rear end ratio?
    Leif
    • Don I.
      • July 20, 2014
      • 34
      The rear end ratio is 3:08.
      • Leif A.
        • August 31, 1997
        • 3627
        Tire size, also, figures into the equation. If you are running standard size tires your should be right at 2000RPM @ 50MPH...in 4th gear.
        Leif
        • Don I.
          • July 20, 2014
          • 34
          I think that's what I'm getting. I'll double check the next time I drive it. Thank you!
