65 rear spring - NCRS Discussion Boards
65 rear spring
  • Bill W.
    • February 29, 1980
    • 2000
    65 rear spring
    I am working on my original rear spring . It seemed to have some kind of dried caked on grease or lube on the liners . Does anybody know what was used on the rear spring when built . Also mine had lots of grey paint left on it .
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 65 rear spring
    I believe all of the leaves were completely painted grey then the liners were installed. There should not be any grease or other materials on the spring. When you see it in place you will see the grey paint and the black liners.
    • Wayne M.
      • February 29, 1980
      • 6414
      Re: 65 rear spring
      Bill -- out of curiosity, does the edge of any one of your springs contain the casting "G.L.S" (Great Lakes Steel, I believe) ? This shot was on one of the shorter spring leaves out of my late '65 L78, standard suspension.
      2nd pic: very little gray (sort-of) paint (Ionoclad ?) remaining. This shot might be from my early '65 014xx.
      c
        • January 31, 1988
        • 43191
        Re: 65 rear spring
        c
        Wayne------
        My 1969 spring had the "GLS" embossment on the side of one of the leaves, exactly as you pictured.
        The gray "paint" was Ionoclad coating. This is an extremely zinc-rich coating. It is no longer available, as far as I know.
        • Keith B.
          • March 7, 2008
          • 928
          Re: 65 rear spring
          I have GM papers that state to use a graphite coating between the spring linners
          • Bill W.
            • February 29, 1980
            • 2000
            Re: 65 rear spring
            Thanks Keith .
            • Bill W.
              • February 29, 1980
              • 2000
              Re: 65 rear spring
              Hi Wayne . You got me , I never noticed that before . I took a quick look at mine and found it on all but one .Some were very small some were bigger . Were they mounted with the letters all facing the same direction or just random ? My std.springs were from 17346 .
                • January 31, 1988
                • 43191
                Re: 65 rear spring
                Bill-------
                The manufacturer's ID was on the steel stock that Rockwell manufactured the springs from. It was not added at the time of spring manufacture. So, it's found in random locations.
                • Gary B.
                  • January 31, 1997
                  • 6967
                  Re: 65 rear spring
                  Keith,
                  The original GM liners were graphite impregnated into polyethylene (At least I think it was polyethylene).
                  Gary
                  • Keith B.
                    • March 7, 2008
                    • 928
                    Re: 65 rear spring
                    Originally posted by Gary Beaupre (28818)
                    Keith,
                    Gary
                    So are the repro liners made that way?
                    • Gary B.
                      • January 31, 1997
                      • 6967
                      Re: 65 rear spring
                      Keith,
                      I don't think I've ever asked any vendors of repro liners what they are made of. If you call Quanta Products, I think they might tell you. Regardless of what they say, the repro liners are different in feel and hue from original GM liners. Unfortunately, the GM liners are discontinued, so repro is the only option if you want new.
                      Gary
                      • Mike E.
                        • June 24, 2012
                        • 920
                        Re: 65 rear spring
                        Bill,
                        Here is a shot of the spring leafs from my from my SB '65. Note this is a 7 leaf spring which it was not originally born with. It too has the gray much like yours. I have since replaced it with the correct spring.
                        Mike
