65 Ignition issue - NCRS Discussion Boards
65 Ignition issue
  • Jan G.
    • December 1, 2005
    • 6
    65 Ignition issue
    I have a 65 Corvette that will not start with key in the start(crank position) , when I turn the key back to the on position it will fire. Anybody have any answers ! Thanks
  • James W.
    • December 1, 1990
    • 2680
    Re: 65 Ignition issue
    Sounds like the ignition switch is bad.
    • Joe C.
      • August 31, 1999
      • 4598
      ....................or the 12v wire between the switch and the coil is broken.
      • Mike Z.
        • 226
        You did not say-is this a conventional or TI ignition system. If TI, your problem is a blown amp power transistor-have it refurbished by someone that can do that work or replace the module with a Delco license reproduction module (much preferred over the M & H board).
        Michael Z
          Assuming point ignition, you're not getting full 12V power from the "R" terminal on the starter solenoid (the small outboard one) back through the black/pink wire to the coil (+) terminal; that's the coil's only source of power when the starter is cranking.
