1963 buzzer tach wiring - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    So I thought that I had 1963 340HP buzzer tach with out the buzzer. It turns out that is does have the buzzer but since there are no wiring diagrams, shop manual, Doc rebuild's, great one, or any place else I have looked that show it, where does the red/pink long wire plug in. It clear that the blue wire with small circular connector plugs into the back of the tach. I would post a picture but I am having trouble with that.
    Jeff
  • Gary F.
    • August 29, 2010
    • 248
    Re: 1963 buzzer tach wiring
    The long Red wire is the " power " wire, and connects to the fuse block at on of the ACC. outlets running along the right side as you face the fusebox from inside the car.
    • Michael G.
      • January 1, 1997
      • 1251
      Jeff
      The red/pink wire on my '63 plugs into a open terminal at the fuse box.
      • Jeff C.
        • 233
        Thanks for the info.
        Jeff
