Continuing A/C fan issue 65 Air roadster - NCRS Discussion Boards
  • John P.
    • August 31, 2002
    • 218
    Hello folks,
    I continue to have an AC fan which functions at low and medium speed, but no High. I replaced the relay with no change.
    The red wire fuse from the harness appears to be intact.
    Does this now suggest a fan switch problem? Am I missing something else? Thanks in advance
    • 6960
    Re: Continuing A/C fan issue 65 Air roadster
    John, Take close look at the relay connector, Sometimes the relay connectors heat up and this may cause a poor or intermittent connection.When the fan speed is on high the motor draws a few amps and this will heat things up like the connectors. What I would do to locate is turn fan speed on high and start by wiggling the connections at relay and fuse connections.
    • Ray G.
      • May 31, 1986
      • 1189
      Hello;
      Trace voltage from source at horn relay with a test light.
      I hope you dance
