Help to identify a green wire on 1963 steering column - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    There were a lot of extra wires under the dash that were there to support a after market radio and a radiator fan switch. So I missed this one when pulled the dash and steering column. Can not find it on any wiring diagram.
    Thanks'
    Jeff
  • Harry S.
    • July 31, 2002
    • 5346
    Re: Help to identify a green wire on 1963 steering column
    That's the wire attached to the upper steering column bearing that is the ground wire for the horn. You need that one.
      • 6960
      There should also be a Brown wire/with black plastic female connector that drops down from left side upper area of the steering column that's hooks to the green wire.
      • Jeff C.
        • 233
        Thank you. That is what was confusing me the green wire.
        Jeff
        • Page C.
          • February 1, 1979
          • 802
          I thought the original wire was black coming from the bearing and the service replacement bearings had the green wire. The 63 guys would know as this as is out of my comfort zone. If it's black then a black magic maker can do wondows
