CI (59) Front and rear Shock replacement - NCRS Discussion Boards
  • Hugh S.
    • May 11, 2014
    • 38
    Hello,
    Is there any new shocks out there now that would be the same as OEM front and rear shocks on my 59? If not, what would be close to orginial OEM shock on a 59?
    Hugh
    member #60,000!!!
  • Mike T.
    • January 1, 1992
    • 568
    Re: CI (59) Front and rear Shock replacement
    Hi Hugh - You musta timed it just right to get that membership number ;-). Now to discuss shocks, it would probably help if you could explain what you mean by 'the same as OEM'? I'm using Monroe Sensa-Tracs on my 61 and wanted to avoid stiffer shocks because my 61 has slightly stiffer front springs, 5-leaf rear springs and Traction Masters. It used to have air shocks out back but that was due to the oversize 255-60's which are now gone. The ride is decent.
    Mike T. - Prescott AZ.
    • Hugh S.
      • May 11, 2014
      • 38
      Hi Mike,
      Thank You for your post. Oh yea. Well I guess is there any shocks that are the same type that was on the 59, when it was new? Probably not, I guess,
      Tires considertion, I have a set of Goodyear radials on the 1959 now the ride is OK/good But I will say they certainlydon't look right.
      All my other antique cars have bias tires and the ride is OK, wondering on the Tires.I forgot, but I see that certanity affects the shocks, and the overall ride-- Good point .
      Hugh #60,000
      Virginia
      • Larry M.
        • January 1, 1992
        • 2701
        Hugh:
        If you want to stay with the original look, Dan Patch can rebuild your old shocks, or may have rebuilt and dated OEM set available for sale. However, they are not inexpensive. His contact info is in the Driveline, or you can contact him through this forum.
        If you just a want a set of decent replacements, AC Delco should have something available. Many of the Corvette suppliers carry the AC Delco units. Of course there are also other brands like Koni, Monroe, etc. Are you looking for something like this for your car??
        Larry
        • Hugh S.
          • May 11, 2014
          • 38
          Larry,
          Thanks Yes, that helps. Just a question about how much are the rebuild orginial shocks?
          Hugh
            • 43247
            Originally posted by Hugh Smith (60000)
            Hi Mike,
            Hugh #60,000
            Virginia
            Hugh------
            No GM or Delco shocks are currently available. It would not matter if they were since they would not be of GM manufacture and would simply be an aftermarket brand shock in a Delco box. GM or Delco has not manufactured a shock in many years.
            You can use Monroe #5751, front, and Monroe #5818, rear. These will appear similar to originals and will provide nearly stock ride characteristics.
            • Hugh S.
              • May 11, 2014
              • 38
              Hey Joe,
              Thank You! wow this Forum is Great! Thank You and all Members -- What a great club!
              Hugh Member # 60,000
              Virginia
              • Edward B.
                • January 1, 1988
                • 537
                Hugh (60,000): Just seeing you name/number come up reminded me of your other issue - any resolution yet on the year dispute?
                • Hugh S.
                  • May 11, 2014
                  • 38
                  Ed,
                  Thanks for note note. Auctions AMerica in Auburn, IN have the Car now and are making it right. I should get the car back soon. They picked the Car up by Reliable Carriers at their expense.
                  Hugh
                  member #60,000
                  • Leif A.
                    • August 31, 1997
                    • 3645
                    Ed,
                    Hugh
                    member #60,000
                    Hugh,
                    I'm sure that everyone who read and commented on your OP would be most interested in how Auctions America is going to "make it right".
                    Leif
                    Leif
                    • William F.
                      • June 9, 2009
                      • 1364
                      Yeah, the ones advertised by vendors-Corvette Central, etc. at least say Delco, contrary to other post that said "no Delco available."
                        • 43247
                        William------
                        The last available Delco shocks were GM #22064272, front, and 22064271, rear. The 22064272 is GM-discontinued. Some of the vendors may have some in stock but that doesn't change the fact that the shocks are no longer available from GM. The 22064271 is not officially discontinued as of yet but I expect it soon will be, assuming stock has not already run out.
                        Neither of the above shocks are manufactured by GM or Delco. As I mentioned, GM or Delco has not manufactured a shock in years. No original Delco PRODUCTION shocks included any labels printed Delco. So, in order to make any shock appear anything like original, labels, including Delco labels, have to be removed.
                        • Dan P.
                          • December 1, 1990
                          • 683
                          Dan Patch 9one3 5one5 372one shocksATdansshocks.com replace the word At with the at sign
