I may have read every post on this and have these questions: can anyone say they have seen an original car with the pointed tip thread cutting style factory installed? What other variations have you seen on original cars?
Many things are said in the threads but I don't recall seeing the above addressed specifically.
1. Two low number guys posted pics and said that the blunt tip thread cutter was correct (maybe only correct) version. I assume they did see original cars.
2. There is much discussion of the variations (pointed, pointed with cut, blunt and blunt with cut), the drawing possibly allowing the variation, and different variations coming out of the same bin under the same part number. Most of this discussion if for pointed tips.
3. There is testimony of less than all four being high hat, often the bottom two which are harder to access.
I think it is implied that all variations were used on Corvettes but I didn't see this said directly.
My car, which I'm sure has been apart before, has only three screws: two blunt high hats without cut (circle and circle with radial marks head marks) on the top and a 5/16 indented hex "L" correct screw on the lower right. I have it apart right now to install a new radiator and would like this answer before I put it back. The high hats seem to cut a looser thread and will not hand thread in the bottom so I'm thinking they were never in the bottom and they may not even be original on the top. The 5/16 fits loosely on top and would likely strip with torque. But I've acquired a handful of pointed tip with cut and double anchor head marks. I could use the advice on whether to use them.
I'll sit back and be learnin' now that I'm subscribed.
