94 LT-1 low oil light switch - NCRS Discussion Boards
  • Keith B.
    • March 7, 2008
    • 928
    does anyone one have a part number for one. got one from the local parts store and the plug is not correct and wanted to sell me anther jumper plug to correct this.
    • 43248
    Re: 94 LT-1 low oil light switch
    Keith-----
    The original sensor was GM #22568381. The latter was discontinued in March, 1997 and replaced by GM #24507190. The latter is also now discontinued but there might still be some around.
    • Keith B.
      • March 7, 2008
      • 928
      thanks. I will call my favorite parts counter on Monday and hope for the best.
        • 43248
        Keith------
        One thing to keep in mind if it matters to you: I believe your original sensor had a steel frame and fitting. I'm pretty sure that the 24507190 is all plastic construction. The current Standard Motor Products sensor is also all plastic and might be the same as the 24507190.
        There is also a current Delco sensor. It's Delco #D8055, aka GM #19112977. I believe it's a Standard Motor Products all plastic sensor in a Delco box.
