Found this on the intake - NCRS Discussion Boards
  • Jeff Y.
    • March 10, 2008
    • 73
    Found this sitting on the intake, did it come from here on the carb? Look at the photos.
    If it did, how do I put it back? The car seemed to be running rough and missing at 4k rpm when accelerating hard. Could this have been messing up my mixture?
    thanks
    Jeff
    • 6960
    Re: Found this on the intake
    Jeff, It appears to be a block off plug, maybe somewhere there is a vacuum leak, this will cause the car to idle rough. I am not sure of the position, maybe if you start the car you'll hear a hissing noise, if so find the source and put your finger over it and you'll feel a slight vacuum. then you found the source of the leak. In your second pic there appears what looks like a open port above the small black hose on the right??
    • Jeff Y.
      • March 10, 2008
      • 73
      That open port on the carb is just to the right of the PVC hose. I'm thinking that's where it came from. Oh, now I see the spot you're talking about. I think that is a screw hole.
      • Bob H.
        • July 31, 2000
        • 829
        Looks like that is where it is from. If you feel vaccum there and decide that is where its from, I would use some epoxy when putting it back in to insure there is not an ongoing leak created.
          • 3422
          Hi Jeff,
          Perhaps here?
          Left side, upper, rear.
          • Jeff Y.
            • March 10, 2008
            • 73
            Alan, yup, that's it. Seemed strange that I didn't have an idle issue. Now I have to work on my timing. I think it's getting too much advance. I backed my initial down and it does not run as rough as before at higher revs.
              • 3422
              Hi Jeff,
              Good!
              Drive on!
