After finding and replacing a bad wire between the ignition switch and the ballast resister I carefully looked at what I thought was every other wire behind the cluster and I could find no bare wires, cracked insulation, or anything else that looked out of place. I even unwrapped most of the bundled wiring and re-taped them afterwards. I re-installed the cluster and proceeded to start the car. What happened then was that as soon as I turned the switch the dome light went out, the fuel gauge pegged right over to the right, and I started getting a bit of smoke from behind the cluster. Obviously a dead short. In a panic I immediately turned off the ignition switch and ran around and disconnected the battery. That was about a month ago.
Now that I have time to get back at it I thought that the first thing I would do is check all the fuses, they are all good. I then thought that like we all do automatically I did not turn the key to "ON" then to "START", I immediately went right past "ON" to "START", so I did not know which position the problem was at or maybe both. The only way to check that out was to turn the switch to "ON" being fully prepared to turn it off immediately and pull the battery power. When I turned the switch to "ON" the dome light stayed on, the fuel gauge went back to normal, and there was no smoke behind the cluster. Being the brave or foolish person that I am I then turned the key to "START" and the starter kicked in. Getting really brave I then cranked the engine over and it started.
Now, I know I have a short or bare wire somewhere and I am probably looking at replacing all or some of the harness in the long term but in the short term, for my own peace of mind, and to be able to drive the car for at least a bit this season, I need to find and repair the problem. Based on the symptoms does anybody have any idea of where to start? Which circuits should I chase down first? Everything appears to be good but there has to be a problem in there somewhere and this could take days to chase down. HELP!!!
