L71? - NCRS Discussion Boards
L71?
  • Mark H.
    • July 23, 2014
    • 19
    L71?
    New here and my first post.
    A friend recently purchased a 1968 Corvette with a not original small block engine in it. Also has a small block hood. Trim tag shows PAINT 900=Tuxedo Black and TRIM 414= Medium Blue. Serial #424032 would be a July 1, 1968 build date.
    After he brought it home I had a look and noticed it had a high rpm (6,500) red line tach. Did a a little research and discovered that tach would indicate an L71, L89 or an L88 engine. So I did more research to see what other telltale signs I could find to indicate the original engine. Here's what I have so far:
    Single fuel line from tank to pump.
    Three holes in fenderwell for K66 TI
    6,500 RPM redline tach
    It also has a big block radiator and shroud and F41 suspension. I believe this would all indicate either an L71 or L89, right? Is there anything else to look for? This car has no documentation so I guess it doesn't really matter but I would just like to document as much as possible.
    Just got the shipping data report which says, "The original delivery dealer was Dealer code 1, Zone 21. The name and location for the dealer was Foreign Distributors Div/Export" After a little research I guess this frequently indicates the car was purchased by a G.I. while overseas and picked up at a dealer in the US. Any way to find out what dealer?
    Maybe while cleaning out the interior we'll find a build sheet. . .right.
  • Ron G.
    • December 1, 1984
    • 866
    Re: L71?
    Two things. First, if it looks like a duck and walks like one, its probably a duck. However, back approx. some 30 years ago give or take, I had a friend, and do still speak with him, he and his Dad removed the original L-71 engine and installed a small block because of fuel usage. At that time the car and my buddy lived in CT. From what he told me it had a blue interior and I thought that the exterior was blue also. Don't know if it was a real black, code 900 car that was re-painted after the car was new. When he had the car no one was looking at trim tags, at least not as many of us do now.
    "SOLID LIFTERS MATTER"
    • Domenic T.
      • January 29, 2010
      • 2452
      Re: L71?
      Mark,
      I did exactly that with my 67 back in 1971. My 427 hood was missing most of the hood frame and had a piece missing from a wreck.
      I put a fresh 365 SB that I had in my shop in it along with a good SB hood on it and ran it for years. I also changed the trans to a 254 1st and took the 4:11 out and put a 3:36 in it.
      Now that I am finishing a frame up I fixed the hood and put the 435 back in it along with a 220 1st and the original 4:11.
      It did happen back then.
      DOM
      • Mark H.
        • July 23, 2014
        • 19
        Re: L71?
        It did come with maintenance records back to 1979. It was in Norfolk, VA then. We contacted that owner and he was unaware that it might have had a big block in it at some point. And the car was painted Lemans Blue then already with the small block hood.
        • Mike T.
          • January 1, 1992
          • 569
          Re: L71?
          Mark - First off, welcome to the NCRS site. I've been a member since the early 90's but just never got around to posting questions till the last few years, shoulda started earlier. On your buddy's '68, you mention it has no documentation but just wanted to ask in case it was overlooked, did you guys look for the tank sticker? Good chance that if there is still one attached to the tank, it's in pretty shabby condition and maybe not readable but worth a look at least.
          Mike T. - Prescott AZ.
          • Rich G.
            • August 31, 2002
            • 1405
            Re: L71?
            Get the 68 Tech Manual and JG and you will see other BB vs SB differences. Not sure, but I think the rear Axels are different or the universal joints. Front sway bar, too?
            Rich
            • Michael F.
              • 745
              Re: L71?
              sounds like you have a good chance the car was original big block, would be nice. good luck and hope it turns out to be. of course, then the journey begins to make it a big block car again.
              Michael
              70 Mulsanne Blue LT-1
              03 Electron Blue Z06
              • Mark H.
                • July 23, 2014
                • 19
                Re: L71?
                Hard to believe somebody would do that, but I remember we all thought fast cars were dead during the gas crunch in the '70s. He wouldn't still have the L71 engine by any chance? Hey, doesn't hurt to hope right?
                • Mark H.
                  • July 23, 2014
                  • 19
                  Re: L71?
                  Thanks for the welcome! We did look for the tank sticker. The seal around the gas filler opening is gone so we could see in fairly well but no luck.
                  • Mark H.
                    • July 23, 2014
                    • 19
                    Re: L71?
                    Originally posted by Rich Gianotti (38594)
                    Get the 68 Tech Manual and JG and you will see other BB vs SB differences. Not sure, but I think the rear Axels are different or the universal joints. Front sway bar, too? Rich
                    Thanks for the tip. We did check the halfshaft u-joint caps and they indicate big block as well.
                    It has the larger diameter front sway bar and rear sway bar.
                    Here's a shot of the radiator and shroud.
                    By the way, I've discovered that the Mallory Mark II Voltmaster coil shown in my first post is worth a few bucks. Seems they were used in the Baldwin-Motion cars. You don't suppose. . . .nah.
                    • Tom R.
                      • June 30, 1993
                      • 4102
                      Re: L71?
                      Mark
                      You have check just about everything but I see no reference to the transmission. You might check it for the VIN derivative and see if it yields information of significance.
                      Tom Russo
                      78 SA NCRS 5 Star Bowtie
                      78 Pace Car L82 M21
                      00 MY/TR/Conv
                      • Mark H.
                        • July 23, 2014
                        • 19
                        Re: L71?
                        Originally posted by Tom Russo (22903)
                        Mark
                        I was thinking there was no VIN derivative on the trans in '68. Am I wrong?
                        • Patrick B.
                          • August 31, 1985
                          • 2011
                          Re: L71?
                          You are wrong.
                          • Mark H.
                            • July 23, 2014
                            • 19
                            Re: L71?
                            Originally posted by Patrick Boyd (9110)
                            You are wrong.
                            OK, thanks for the correction. Can somebody fill me in on the location of the transmission numbers and how to decipher them?
                            • Tom R.
                              • June 30, 1993
                              • 4102
                              Re: L71?
                              Help us out here...what have you got? Auto or four-speed?
                              Tom Russo
                              78 Pace Car L82 M21
                              00 MY/TR/Conv
