1969 BB radiator removal - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    Can the radiator and core support be pulled from below if the front cross member is removed first?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1969 BB radiator removal
    Never tried that, but the shape would indicate NO. I dont see why you would want or need to do that.
    • Roger G.
      • October 11, 2012
      • 268
      Getting ready to replace the front crossmember .... And just discovered a leak in the radiator ....2 birds with one stone?
        • 43248
        roger------
        In this case, I don't think you can "kill two birds with one stone". However, having the crossmember out may ease the radiator replacement effort.
        • Wayne W.
          • April 30, 1982
          • 3605
          Just remove the hood and take it out the top. No need to re-invent that wheel.
          • Bill C.
            • July 15, 2007
            • 904
            not 100% sure but I think the core support is not perfectly square (a little wider at top) so that would make slipping it down difficult.
            Also - think the sway bar assembly would have to be completely removed and the front bumper horseshoe too.
            basically - don't think so but who knows.. :-)
            I would just take the hood off and take the radiator out from up top. it works. :-)
              • 43248
              Originally posted by Bill Chamberlain (47576)
              ...not 100% sure but I think the core support is not perfectly square (a little wider at top)
              Bill----
              Yup, that's how it is.
              • Roger G.
                • October 11, 2012
                • 268
                Thanks guys... Somehow I knew it wouldn't be that easy
