67 front bumper bolts - NCRS Discussion Boards
  • Robert D.
    • April 1, 2003
    • 305
    i removed my front bumpers to clean them and found that the 4 bolts which connected the front crossmember to the center bumper brackets were grade 8 bolts with an "M" marking according to the manual it should be a grade 2 bolt has anyone ever seen this or were these replaced the length and width of the bolts is correct
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 67 front bumper bolts
    Robert, IMO these grade eight (M) bolts look to be from the rear where the crossmember bolts to the frame or from the brake caliper bracket mounting.
      Robert -
      Those (8) bolts (#122253) aren't described in the '67 JG (other than they're silver zincad), but they're the same bolt that's used to secure the bottom end of the outboard seat belt reinforcement cable to the frame.
      • Bill M.
        • 1328
        Robwere the spacers in between the bumper brackets?Bill
        • Joe R.
          • July 31, 1976
          • 4551
          Robert,
          The bolts you show are indeed the correct bolts for the lower front bumper braces. The four grade 8 M bolts are to secure the front brackets to the front crossmember and the four grade 8 WB bolts are to secure the lower bumpers to the brackets. There is indeed a sleeve inside the lower bumper braces. As for the finish, I have never seen any grade 8 for the front bumpers that were not black phosphate.
          JR
          • Gary B.
            • February 1, 1997
            • 7053
            Originally posted by Joe Ray (1011)
            Robert,
            JR
            Joe,
            I agree with you on the four WB bolts (grade 8, black phosphate), but as John Hinckley says, the GM #122253 bolts are the same as the ones used to secure the outboard seat belt reinforcement cables, and known originals of those bolts are grade 2, not grade 8. And those seat belt cable bolts are known to be zinc/cad, not black phosphate. And to the best of my knowledge, only the four WB bumper hardware bolts are black phosphate, at least for 63-66, but I think '67 also. So, I don't think grade 8 and black phosphate are correct for GM #122253.
            Gary
            • Robert D.
              • April 1, 2003
              • 305
              Hi guys thanx for all your input
              Bill there are spacers in between the bumper brakets
              Joe the WB bolts were black phosphate they were so rusted that i wire wheeled the rust and coating off of the head the the shaft of the bolts were obviosly black phosphated the M grade 8 bolt were zinc coated
              • Rich P.
                • January 12, 2009
                • 1361
                All C2 1-1/4" front and rear bumper bolts are grade 2. If the grade 8 M bolts are 1-1/8" long they are the rear end crossmember to rear mounting bolts, if they are 1-1/4" they are for the rear crossmember to frame bolts.
