Is this original 66 fiberglass? - NCRS Discussion Boards
  • Scott G.
    • August 31, 1984
    • 132
    I am looking to replace the sheet molded part on my 66 for an original style piece.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Is this original 66 fiberglass?
    It looks original as best as I can see from the photo. Does it have a part number molded into it at the lower center?
    • Joseph T.
      • March 1, 1986
      • 169
      Looks good to me. How does it compare to the color of the fiberglass currently on the inner portion of the rear fenders?
      • Scott G.
        • August 31, 1984
        • 132
        Here is the center section photo. I'm doing this by long distance. The seller has provided the photos. I have asked for some from closer up.Panel center.jpg
        • Scott G.
          • August 31, 1984
          • 132
          Just as I posted the previous, I received a better photo from the seller. Panel center 2.jpg
          • Russ S.
            • April 30, 1982
            • 2163
            Looks like a winner.
            Originally posted by Scott Goings (7829)
            Just as I posted the previous, I received a better photo from the seller. [ATTACH=CONFIG]54216[/ATTACH]
            • Russ S.
              • April 30, 1982
              • 2163
              If you have it shipped be sure to have shipper back it with something(like plywood) to protect it.
              • Scott G.
                • August 31, 1984
                • 132
                Is that molded in number unique to the correct part?
                • Gene M.
                  • April 1, 1985
                  • 4233
                  The darker glass as in 67 can be in the mid to late 66 year. Also the lighter gray is quite common in the early to mid 66. So depending on the build may follow those trends. It's not uncommon to see light gray on some of the panels in early 67's built in 66.
                  • Russ S.
                    • April 30, 1982
                    • 2163
                    I don't quite understand your question as all parts have a part number that is unique to a correct part as do incorrect parts have a part number that is unique to an incorrect part. It is an original correct part.
                    • Scott G.
                      • August 31, 1984
                      • 132
                      Thank you for the response. What is was trying to ask was: Is this part number only on the original parts or do the later parts molded with the newer material also carry the same part number?
                      • Russ S.
                        • April 30, 1982
                        • 2163
                        There are a couple of different repos available so I can't say for sure but I don't think any of them have part numbers on them like the originals.
