C2 Horns - NCRS Discussion Boards
C2 Horns
  • Patrick B.
    • August 31, 1985
    • 2003
    C2 Horns
    Is there any way to disassemble and repair an original 67 horn. It made a sickly squak and now no sound. The electrical resistance is extremely high so there is probably a discontinuity in the coil. The replacements are apparently plastic which would be a big difference in appearance. Do other GM cars of the era have the same horn?
  • Keith B.
    • March 7, 2008
    • 928
    Re: C2 Horns
    LIC sells a rebuild kit that had every thing you need. All you do is drill out all the rivets. The horn comes in half. You replace the diaphragm inside and then reassemble. The trick is duplicate the rivet marks
      Re: C2 Horns
      It's a lot simpler to send it to Gary at the Horn Works (www.classiccarhorns.com) or to Joe Perri in Chicago - either way, it'll come back working, correct, and ready to bolt on. The "DIY-at-home" horn rebuild kits are notoriously unsuccessful.
      • Keith B.
        • March 7, 2008
        • 928
        Re: C2 Horns
        John I rebuilt a couple horns with success.
        • Lawrence S.
          • April 1, 1993
          • 803
          Re: C2 Horns
          I have used both of these guys with great success. I agree with John on this work.
          • Scott G.
            • August 31, 1984
            • 132
            Re: C2 Horns
            I rebuilt a set of 66 horns with the DIY kit almost thirty years ago. They still work fine today.
            • Joe C.
              • August 31, 1999
              • 4598
              Re: C2 Horns
              I agree.
              I duplicated the waffle rivets as well.
              The key, I believe, is to make sure that the two halves are dead flat, otherwise the diaphragm will deform and not vibrate.
