1963 DIY for Mechanical Clock Works - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    Some years ago I thought there was a vendor who had a kit to redo the original works of the clock. I have searched the web and not found anyone who sells such a kit. Anyone know of a supplier?
    Jeff
  • Gene M.
    • April 1, 1985
    • 4232
    Re: 1963 DIY for Mechanical Clock Works
    Jeff,
    I don't know of any supplier today. I get used clocks from the junk yard. They are all the same movement for cars of that era. Mix and match parts to get a good one. Most of the time a bit of filing on the points gets them to life. I've got 4 running now in my cars.
    • Gary R.
      • April 1, 1989
      • 1804
      What about the quartz conversions? I use one in my 72 and it hasn't stopped in the last 8 years.
      • Tim S.
        • May 31, 1990
        • 715
        They work great, just wont pass judging. Tim
        • Gary R.
          • April 1, 1989
          • 1804
          Hi Tim.What fails during inspection, the action of the second hand? I have to admit I never paid it much attention as I was happy to have a corvette with a working clock!
          • Tim S.
            • May 31, 1990
            • 715
            Exactly. The original movement is not a smooth sweep like the quartz. I agree, a working clock is kinda novel! Tim
            • Jeff C.
              • 233
              Gene,
              Do you think it worth pulling apart and seeing if there are some minor repairs such as the points that might fix it. Operations judging, quartz clock minus 25, non operating clock minus 25 points. If nothing else I can clean up the lens.
              Jeff
              • Harry S.
                • July 31, 2002
                • 5338
                Jeff, read through this about a C2 clock. This is a current thread.
                https://www.forums.ncrs.org/showthre...tance-Criteria
                • Gene M.
                  • April 1, 1985
                  • 4232
                  Originally posted by Jeff Cheney (29688)
                  Gene,
                  Jeff
                  I would. You only need to remove the outer housing to get to the movement. Most times a jewelers file will clean up the points. Be gentile as it is fragile.
                  • Jeff C.
                    • 233
                    Gene, Everything looks good except points. Filed them and am going to hook up clock to battery. Any issues I should be careful about?
                    Jeff
