Hello,
It appears my secondary's are not opening under hard acceleration and I don't get the expected surge in acceleration as if the secondarys were opening. When I run thru the gears shifting between 4500-5000 the acceleration seams very linear with no real surge.
I don't have much experience driving other cars of this nature so I don't have anything to compare it to.
I installed a paper clip on the secondary rod to see if i was getting any movement on a test run and the paper clip didn't move. I checked the secondary spring and it was plain with no color code, I inspected the little seal on the housing and the venturi hole and it was not clogged, the diaphragm seal is good.
I changed the vacuum secondary spring to the lightest spring in the Holley kit, and I am only getting about 1/4 - 3/8" of movement based on the paper clip movement on the vacuum diaphragm rod. I would think it would open all the way, but its not. I haven't ran it past 5500RPM
The engine is bored 60 over, all parts are LT1 spec, cam, pistons, heads, exhaust manifold/exhaust, etc.. original 4489 carb, 4:11 gear. I did change the power valve from I think a 8.5 to I think a 5.5 based on the vacuum at idle. The floats are adjusted correctly, the jets are stock. I do have the TCS hooked up and operational, the distributor is original TI and has been rebuilt by Dave Fiedler to OEM specs. Timing is set at 10 BTC at 750 RPM.
Is this normal acceleration for the LT1? Will the secondarys open more beyond 5500RPM? The engine seems to run great just a little flat when accelerating.
Any thoughts?
Any thoughts?
