'67 engine stamping pad - NCRS Discussion Boards
  • Tony S.
    NCRS Vice President, Director Region VII & 10
    • April 30, 1981
    • 990
    Anyone want to venture a guess on this pad?
    Thanks...
    Tony
    Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
    Original member of the Kansas City Chapter, est'd 07/11/1982.
    Member: 1965 and 1966 National Judging Teams
    Judging Chairman--Kansas City Chapter.
    Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
  • Michael G.
    • January 1, 1997
    • 1251
    Re: '67 engine stamping pad
    I'll take a stab Tony. It's from a '67.....just a wild guess here, a Corvette. The '2' in the VIN stamp stands out as cut deeper into block and looking not typical. What do you see?
    • Jimmy G.
      • November 1, 1979
      • 977
      Looks like someone hit the wrong number then changed it Happened more that you think At least this guy caught his mistake
      • Tony S.
        • April 30, 1981
        • 990
        I looked at this car recently and wanted to get some thoughts on the pad. This car is for sale in the KC area and appears to be a California A.I.R. car. I'm not a stamp pad expert so I'd like to get others opinions about the pad and if it appears original.
        • Larry M.
          • January 1, 1992
          • 2701
          Based on the photo provided, I would say the pad is original as stamped by GM. The final "2" in the VIN is obviously not typical, but I still feel it is an original. FWIW
          Larry
          • Ara G.
            • January 31, 2008
            • 1108
            That "7" sure doesn't look evenly spaced with the other numbers and also looks higher on the pad the other numbers in the VIN. Might be the angle of the picture, but I don't think so.....ARA.....ALSO, when you saw the pad, was there a "1" underneath that funky 2? I ask because IF the factory did this, it would be because they forgot to change the number for the next car in line....so I would guess seeing a "1" underneath that funky 2 would make sense....
            • Robert G.
              • May 31, 1990
              • 429
              Here's what the car before it looked like.
              • Leif A.
                • August 31, 1997
                • 3645
                [ATTACH=CONFIG]54122[/ATTACH]
                Major difference in the diameter of the "0" and a different looking "6". The OP vin pad appears to be double-stamped.
                Leif
                • Joseph T.
                  • March 1, 1986
                  • 169
                  Stamp looks original to me- Different 0 and 6 is because DATE is stamped at Flint and the VIN # is stamped at St Louis and the Engine configurations are different.
                  • Rob M.
                    • April 30, 2003
                    • 657
                    I agree with Joseph. I'm not an expert, but it looks right to me. The 2 does look like it was struck as a correction, but that would not surprise too many people as having been possible. The 7 looks the same in both vin stamps too. FWIW
                    Rob
                    '66 327/300 Regional Top Flt
                    '08 6 speed coupe
                    • Joe R.
                      • July 31, 1976
                      • 4551
                      Way too much chatter about the numbers being out of line. The fact is that GM did not change the holders and as they aged the numbers were not held straight. When a perfect stamp appears, there is a red flag that goes up.
                      JR
