58 rear crossmember - NCRS Discussion Boards
58 rear crossmember
  • Brandon T.
    • October 23, 2008
    • 872
    58 rear crossmember
    Replacing my rear crossmember on my 58. Does the new rivets go in from the bottom side and rivited on the top side. My old one was bolted on which I know is not correct.
  • Thomas H.
    • August 31, 2005
    • 1058
    Re: 58 rear crossmember
    Brandon,
    Keep in mind the frames were assembled upside down so the workers would drop them in and buck them. When you looked under an assembled car, you would see the head. (double checked my 58 just to be sure).
    Tom
    2007 Z06, Lemans Blue
    • Brandon T.
      • October 23, 2008
      • 872
      Thanks Thomas, that is how i thought they are installed but I have seen them installed with the head up on some cars.
      • Dino L.
        • February 1, 1996
        • 694
        What is the proper technique to do these rivets.....do they need heated while they are bucked.....what tools and techniques do you use?
        Dino Lanno
          Dino -
          The original rivets were set (cold) using a 2000 psi hydraulic rivet-setter, similar to those used next door on many locations on the Truck frame line. With that kind of tooling, heating wasn't necessary.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17659
            Dino,
            I cut off the old rivets. Welded the replacement bracket onto the frame. Then welded the rivet head and ends in place.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
