1963 Spark Plugs Resistor or Nonresistor - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    Were the factory spark plugs AC-44 or AC-44R?
  • Jeff C.
    • 233
    Re: 1963 Spark Plugs Resistor or Nonresistor
    Found my answer.
      • 15706
      Resistor plugs did not become production standard until 1969. Non-resistor plugs are no longer offered by "AC", and they no longer offer heat range 4, but heat range 5 is more resistant to fouling than 4, which is why I ran AC 45 back in the day, but today they are only available as AC R45 resistor type.
      Beware, the current AC catalog calls out heat range three for most applications, which is way too cold for normal road driving.
      Non-resistor equivalents to the old AC 45 are offered by NGK and Denso, B4 and T14-U, respectively.
      • William F.
        • June 9, 2009
        • 1364
        Duke,
        Do NGK and Denso still make the nonresistor plugs you mentioned as AC 45 equivalents?
          • 15706
          I haven't checked in the last week or so, but I expect they are still available, though probably not commonly stocked at NGK retailers.
