DSC_1490.jpgDSC_1491.jpgDSC_1497.jpgDSC_1496.jpgIt seems many 65 /66 BB hood skins are not bonded to the underside . I found a 3M product that does a great job . 3M # 8115 panel bond . It looks good seems strong , its been on mine about a week . We used it at work to bond roofs , door skins , etc. The only hard part is cleaning all the old bond off first .
					65 BB hood frame loose
Re: 65 BB hood frame loose
I used a similar product by Locktite. The only thing different I did not firmly clamp together with glue. The glue does not dry rock hard so there is always some give since fiberglass does want to "move".- Top
- Top
You can get it and any body shop supply store that sells 3M .You do need a special gun to use it . It does flex slightly . I have two other hoods a 66 grey BB that there is no bond on ???and a new GM hood I bought in about 1981 that has bond . On my 65 white glass hood there was bond residue and you could see an outline where the bond had been before the hood was primed at the factory . It still had the factory prime and black out on it . I think it was bonded when new . The 66 hood I don't know ?- Top
I used 3M 06564 4200 fast cure. It is a Marine polyurethane. It will stay pliable but firm even though it does have some adhesive features. Mine is not a judged car so don`t send the emails. Thanks Mike- Top
Hi Bill I saw no evidence of it but this is actually a 66 hood going on my 65 small block car.- Top
Bill it was gray in color. Or a dirty white color. I put wedges under the frame to pick it up and put a puddle of the urethane down and took the wedges out so that it pushed the material out a little. it looked close to what I had seen in pictures of original. I don`t think it ever had any by the original pictures. MikeAttached Files- Top
Bill. You would have seen evidence of dum-dum, non hardening material to cushion and dampen vibrations, but it was not bonded.You can get it and any body shop supply store that sells 3M .You do need a special gun to use it . It does flex slightly . I have two other hoods a 66 grey BB that there is no bond on ???and a new GM hood I bought in about 1981 that has bond . On my 65 white glass hood there was bond residue and you could see an outline where the bond had been before the hood was primed at the factory . It still had the factory prime and black out on it . I think it was bonded when new . The 66 hood I don't know ?- Top
Guys,
Here are some pictures I took of a red '65 big block at Bloomington and a green big block Duntov/Bowtie car at the 2008 NCRS National Convention. These are the best pictures I could find of the bottom side of the hood bonding material. Hope it helps.
James West- Top
