Job Number help - 1966 AOS - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hi Everyone,
    I recently found what I believe to be a job number written in yellow on my AOS built '66 (VIN 17534 - March 16) and I'm having a hard time trying to figure out what the number reads - so I'm looking for opinions/thoughts from those who have more experience or exposure to the numbers than I.
    The number is on the passenger side on the underside of the rear deck of my convertible. At first glance I believed it to be a 48, but it's got this weird squiggle at the top of the second number. No doubt the first number is a 4.
    A couple of the pictures were taken with a mirror.
    I'd appreciate your thoughts....
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Job Number help - 1966 AOS
    Kurt,
    How about 317? first # a 3, then a 1 on top of the 3 followed by a 7 with a cross line?
    • Wayne W.
      • April 30, 1982
      • 3605
      Look on the bulkhead in front of the gas tank, and the passenger floor kick panel for the body number. Usually the numbers on the fiberglass panels were for individual panel record numbers. AOS will have a number and then a letter.
      • Don H.
        Moderator
        • June 16, 2009
        • 2257
        If they used number and letter, then I would call this 4E
        • R N.
          • May 31, 2002
          • 640
          I didn't know about the number and letter thing, but had noticed a few examples of this from the C2 Registry. I'm thinking what Don says is correct. Heck I even write my capital "E" in a similar fashion.
          Added to my "to do list" is to look for the job number in the other spots that Wayne has suggested.
          • Rob M.
            • April 30, 2003
            • 657
            Kurt,
            AO Smith did use a letter before the job number starting with A and moving through the alphabet in batches of 500. I know my 66, AO Smith, #21064 has a job number of of V31. I have found it in several places. However, not every where I found the job number had that letter before it. the job number I found under the dash was only 31.
            So, your March car would most likely not started with an "E" as that would have been earlier in the build year. I actually think your number is a 38. The 3 has a loop on the bottom and the 8 is made in one motion. For what it's worth.
            I would look under the passenger foot well in the engine compartment. You might need to pull the splash shield and use some dish soap and water to clean it up, but that is where you should find another job number for your car.
            Here is a picture of my job number on the footwell. FYI, it's written sideways V31.
            Rob
            '66 327/300 Regional Top Flt
            '08 6 speed coupe
            • R N.
              • May 31, 2002
              • 640
              Originally posted by Rob Myrick (39795)
              Kurt,
              Rob,
              Thanks for the additional info..... Where under the dash did you find your number? Can it be seen w/o taking everything apart?
              • Rob M.
                • April 30, 2003
                • 657
                Kurt,
                It is on the driver's side, written on top of the brace/bar and is about 5 or 6" left of the clock. I saw it when I had the dash out of the car. I tried posting a picture of it, but couldn't load it (must be too big a file).
                Rob
                '08 6 speed coupe
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  You will also find another number on the face of the metal bar behind the dash cluster, however that number is not the same.
                  • Rob M.
                    • April 30, 2003
                    • 657
                    Kurt,
                    After looking at it more, I agree with you and think its "48" FWIW
                    Rob
                    '08 6 speed coupe
                    • Tony S.
                      NCRS Vice President, Director Region VII & 10
                      • April 30, 1981
                      • 988
                      Great photo example of the green on your AOS car. We definitely look for the green when judging AOS cars.
                      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                      Original member of the Kansas City Chapter, est'd 07/11/1982.
                      Member: 1965 and 1966 National Judging Teams
                      Judging Chairman--Kansas City Chapter.
                      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                      • Ara G.
                        • January 31, 2008
                        • 1108
                        Tony I was thinking the EXACT SAME THING
                        • R N.
                          • May 31, 2002
                          • 640
                          Some more examples of the green primer.....
                            Tony -
                            Note that in these examples, you'd see green zinc chromate primer regardless of St. Louis-vs-AOS body source, as the photos are of birdcage components, and the birdcage was painted green at both plants.
                            • Wayne W.
                              • April 30, 1982
                              • 3605
                              You might also note AOS tendency not to blackout the Bar behind the tags.
                              https://www.forums.ncrs.org/attachme...7&d=1406312847
