66' turn signal woes...... - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Hello to all;
    My 66' big block was recently (completely) restored & I noticed the following issue while driving this week. The left hand turn signal function works perfectly. However, when I go for a right hand turn........ the indicator light in my dash flickers and all for corner lights on the car also 'flicker' in a sputtering mode. What could be the cause ?! Thanks in advance !
    • 6960
    Re: 66' turn signal woes......
    David sounds like you have something, behind the steering wheel that must be hitting or rubbing the wire harness.Steering shaft??? It may require removing the steering wheel to locate the problem.I know the harness is routed inside the column, If for some reason the wires are rubbing something metal internally and the installation may worn through causing the wire (s) to ground and cause a problem..
    • Leif A.
      • August 31, 1997
      • 3658
      Sounds like a ground issue, for sure. Hate those electrical gremlins Congrats on your recent resto!!
      Leif
