Hello NCRS members!
My plugs foul after 3-or-4 drives, so I'm restoring the dual quads. I understand running the Holley fuel pump can make things rich, so I putting on a restored correct Carter fuel pump.
Am I correct it's best to disconnect fuel line near gas tank so the flow of gravity is stopped. Otherwise, disconnecting near fuel pump will make a lot of gas constantly flow out and hard to work with trying to plug the line.
Thank you,
Eric
Thank you,
Eric
