Re: Idle Overheating
I believe I've had the current cooling condition for many years. I have always just tried to avoid prolonged idle. What I did not appreciate until very recently was that may temp gauge is actually reading LOW by about 15 deg, when most read high. Its too easy to get stuck in bad traffic here, and pushing up to 260 is just too high for my liking.
The OEM rad had a whole new core put in when rebuilt. Its hard for me to compare before/after rad rebuild - as I also had the cluster and gauges done at similar time.
I ordered a Robertshaw 330-180 thermostat and a Hayden 2711 fan clutch last night. The Hayden is cheap - if it helps - I will get my OEM Eaton rebuilt. I have replaced the fan to correct, but have never touched the clutch.
