My 69 makes seems to make a lot of fan noise. I have an aftermarket fan clutch which is a little larger in OD than factory orig. I believe the fan is factory. This is a freshly restored car. Any thoughts on this?
1969 BB Fan Noise
Re: 1969 BB Fan Noise
Herb, Some fan noise is normal, when started in the AM sometimes for a minute or two the fan will sound like a turbo prop. If your hearing any longer than that Your fan clutch may be defective or just the wrong one.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Herb-----
Keep this in mind: generally, the more noise it makes, the more air it is pulling. This can be a good thing with Corvettes.In Appreciation of John Hinckley- Top
