63 Turn Signal Capacitor - NCRS Discussion Boards
  • Norm B.
    • 360
    So here I was unhappily removing the steering column on my '63 for n'th time. When I unplugged the wires at the turn signal switch at the bottom the clip for the capacitor fell onto the floor. Looks like a pretty straightforward job to reattach the clip but once that is done I am a little baffled on how or where it attaches. Is there any particular tab it should be on? Does it go into the clip first? Just how is thing oriented? If anyone has a picture that would be a great help.
    Thanks, Norm
    Golf is for those who can't play​ hockey.
    • 6955
    Re: 63 Turn Signal Capacitor
    Norm, I am sure that the AIM will show or tell you which spade it goes on. Look at the AM U65 section I believe that's shows. The AM radio only mounts the capacitor on the column turn signal switch.
    • Norm B.
      • 360
      Thanks Edward, found it. There is enough detail in the AIM to answer my questions.
