54 brake systems - NCRS Discussion Boards
54 brake systems
  • Guy M.
    • November 1, 1993
    • 500
    54 brake systems
    Hi everyone Two Questions. Im having trouble getting my rebuilt master cylinder to seal at the two big bolts on the end. I have new crush washers in on the smaller bolt. Re using the big one. I pump it up to 15 psi with soaped joints but not holding there. Do any of you use teflon tape on screw threads or other sealing methods. Also, should all piston cups in wheel cylinders move easily with finger pressure? Ithink I might have to take the rubber covers off the cylinders and soap the pistons to see if they are holding. This beats using fluid to find leaks. Thanks again!!!
    • 6960
    Re: 54 brake systems
    Guy, sometime sealing those style fittings with gaskets require loosening and tighten the fitting a few times, and really cranking it tight on the final tighten. no sealant should be needed. and the as far as the wheel cylinders, if the wheel cylinder are full of fluid there will be some resistance. If the wheel cylinders are old I would peel back the rubber boots and look for signs of fluid or rust. and for safety If they are more than 4 or 5 years old I would replace. the quality of the replacements are not so good.
    • Guy M.
      • November 1, 1993
      • 500
      Thanks ED, My system is new and dry although I honed the original rears 7 or 8 years ago and rebuilt them. Im willing to take off all the cylinders and check for ease of piston movement if I have to. Seems they should move relitivle easy for proper operation
      . Ill crank on some of these fittings again I guess. The goal is to hold 15 psi indefinitly. Ill peel all the boots back and hit it soap water to check for leaks. With all being new just goes to show you still have to screw with everything.
      • Chris S.
        • January 1, 2000
        • 1069
        Guy,
        I had a terrible time getting my master cylinder to stop leaking at the block - in the front.
        The rear crush washer would not seal - I changed washers several times...
        I ended up using a thick alum drain plug washer -
        Finally - no leaks
        Down side at Regional and Nationals I get dinged for not having a copper washer.
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Guy M.
          • November 1, 1993
          • 500
          Thanks Chris, Im glad its not just me. I had to use a big --- wrench and cranked on it so hard I thought I was going to break something. It finnaly sealed. I highly recommend that pressure bleeder fron CC. It sure beats testing with fluid. Thanks again!
          • Tim E.
            • April 1, 1993
            • 360
            Guy - I was introduced to a product called "EZ Turn (Fuellube)" sold by Aircraft Spruce & Specialty Co. It comes in a 5oz tube which will be a lifetime supply! The sealant was developed for the aircraft industry and is used on the faces of the mating surfaces of both brake and fuel line connections. Spread a small amount right where the tubing flare or, in this case, both sides of the crush washer touch. The sealant comes out of the tube the consistency of caulk and remains semi-hard. It is designed for use with fuels and brake fluid. Tim
            • Guy M.
              • November 1, 1993
              • 500
              Thanks Tim, this will help everyone who has been pulling thier hair out. I just ordered a tube. $17 including shipping. Great tip!!!
