75 small block AIR pump - NCRS Discussion Boards
  • Ross F.
    • August 31, 2004
    • 167
    I am putting my motor back together and I don't think I have it correctly mounted.
    I followed the AIM and all my books, but it still looks funny.
    • 6941
    Re: 75 small block AIR pump
    Ross, is there suppose to be a stud in the lower mounting at the water pump instead of a bolt. It appears your air pump is close to the plastic vacuum sensor. So it would appear stud first, spacer, bracket, locking nut? the stud would give you about 3/16 to 1/4 more spacing.
    • Ross F.
      • August 31, 2004
      • 167
      Ed,
      The assembly manual does not show a stud on the passenger side of the of the water pump.
      Plus the way it fastens to the intake wouldnt allow much movement
        • 6941
        Ross, It appears like the front is doing a nose dive? is the vacuum switch against the pump? Maybe another pic. of the opposite side with lower bracket will help.
        • Ross F.
          • August 31, 2004
          • 167
          Ed,
          I will get more photos. you're right though. It does seem to tip forward and sideways. I don't get it, it I all the same stuff I took off.
          It is hitting the vacuum switch.
          • George L.
            • August 6, 2013
            • 15
            Here are a few pictures from my 1975 with the base engine. I hope these help you out.
            George
            • George L.
              • August 6, 2013
              • 15
              Here are a few more. I hope they help you out.
              Good luck,
              George
              • Ross F.
                • August 31, 2004
                • 167
                George,
                Great pics. That is exactly how mine is mounted as I have C 60 brackets.
                There isnt much clearance with the vacuum switch.
                I bought belts from quanta. But all of them seem too short.
                Do you have the part numbers on your bracket and pulley? Are the number out or towards the pump?
                  • 6941
                  Ross, If you have a auto parts store near by have them look up the part numbers for you. just to see how close the lengths are to Quanta's belts. The part numbers like Gates uses are the length and width. (such as part no 7545 - 7= 3/8 width, 545 = 54.5 Inchs). Some time GM part numbered belts can be a odd length so they will sometimes use belt that are 54.25 and the after market will use a 54.5 so if you have a AIM bring the part numbers to store with you they can also cross ref. them.
                  • George L.
                    • August 6, 2013
                    • 15
                    Originally posted by Ross Flora (42403)
                    George,
                    I have a P/N on the pulley: 3927116AU
                    Let me know if you need any further information.
                    George
