S/B Exhaust Manifold French Locks - NCRS Discussion Boards
  • Roger D.
    • June 3, 2014
    • 180
    Purchased a set of French locks for the exhaust manifolds and they are shiny silver. Should they be blackened before I make the one bend over the bolt. I assume the bend is the front outside tab of each bolt, or does it matter. Well I read Joe L. French lock info so the early 69 S/B does not use French locks but a GM bolt # 3909821. Can you stil get these bolts and where might one find them. Thank YouRoger
    • 43248
    Re: S/B Exhaust Manifold French Locks
    Roger-------
    If I ever said what you said I said, then I must have been having delusions. ALL 1969 small blocks were equipped with french locks on the end exhaust manifold bolts. The GM #3909821 locking bolt was used only for BIG BLOCKS.
    The french locks don't need to be "blackened". Natural steel is what they were. Of course, they will rust quickly. That's why I use stainless steel locks, albeit incorrect.
      • 3416
      Hi Joe,
      Speaking of french locks…. the 'tabs' on the locks from my 71 base sb are round, while the locks available now have square tabs.
      Were locks with round 'tabs' typically used when the manifolds were installed in St.Louis, or might there have been square 'tabs' too?
      • Roger D.
        • June 3, 2014
        • 180
        Roger-------If I ever said what you said I said, then I must have been having delusions. ALL 1969 small blocks were equipped with french locks on the end exhaust manifold bolts. The GM #3909821 locking bolt was used only for BIG BLOCKS.The french locks don't need to be "blackened". Natural steel is what they were. Of course, they will rust quickly. That's why I use stainless steel locks, albeit incorrect.
        Thanks Joe, I notice that as I get older I am screwing up allot of things that I am reading. My bad. ThanksRoger
        • Roger D.
          • June 3, 2014
          • 180
          Please correct me if I am wrong but I did not think the 1969 base model 350/300 had French locks on the rear flange of the half shafts. I f so I will need to get them, OOPs!!
            Alan -
            The small-block exhaust manifolds were installed at the Flint V-8 Engine Plant. but the bolts were removed/re-installed at St. Louis to install the horizontal ignition shielding brackets.
              • 43248
              Roger-----
              French locks were used on the half shaft flanges for ALL 1969 Corvette applications (as well as all other 1964-82 Corvette applications).
              • Christopher K.
                • September 10, 2007
                • 311
                Hi Joe,
                Great question - I was wondering about the same thing. Mine are round on my '72 sb also.
                Chris
                '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
                '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
                  • 3416
                  • Roger D.
                    • June 3, 2014
                    • 180
                    Thanks Joe, I will get a set tomorrow.
                    • Peter S.
                      • March 28, 2012
                      • 327
                      Hey Roger,
                      Here is a french lock off of my '69. I believe these were replaced in 1971 as part of my Chevrolet Engine replacement, so I cannot fully confirm for you the configuration of the "ears" in respect to 1969. My manifolds are dated correctly and were attached to dated correct heads, and I had to drill out two of the exhaust manifold bolts. This is my sole basis to believe that they have not been replaced since 1971. But, maybe it will help clarify the roundness of them?
                      Maybe it will help clarify the bend?
                      • Roger D.
                        • June 3, 2014
                        • 180
                        Thanks for the pictures Peter, they help me a lot. I think Paragon and Zip have the rounded locks so I will go to them first. Thank youRoger
