1963 Exhaust Hanger Rivet Installation - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1311
    Hi,I purchased a repair kit for my 63 hanger and I'm looking for the proper way to "crimp" or "squash" this attaching rivet. Any thoughts?Thanks,Jerry
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: 1963 Exhaust Hanger Rivet Installation
    Gerald, You will need a tubular rivet set of the proper size. They are availible here... http://www.rivetsinstock.com/rivet-t...vet-tools.html
    • Gerald C.
      • June 30, 1987
      • 1311
      Tracy,I took a look at this site and found the kits were kind of expensive for a one time use. Any other thoughts?Thanks,Jerry
        • 6956
        Jerry, if you have a old round punch that's big enough you can dish it out and lay the hanger on a flat section of a vise and flatten the rivet, really likely you will not see the flatten side if you face it to the cross member side. and should work fine.
        • Gerald C.
          • June 30, 1987
          • 1311
          Ed,I do have some hole punches. My vise is not big enough to open that wide. I may try to lay the hanger on an anvil base and use a hammer to drive the punch into the rivet. That might work??Jerry
            • 6956
            Yes that's what I was trying to explain. anything you can use to peen over the rivet is fine.
            • Gerald C.
              • June 30, 1987
              • 1311
              Thanks. I'll give it a shot later today
