What are the right spark plugs - NCRS Discussion Boards
+ More Options
Posts
  • Roger D.
    • June 3, 2014
    • 180
    What are the right plugs for my 1969 restore. Car had bosch plugs. Car is 350/300 hp bored 30 over with a mild cam. To be original i guess some sort of ac plug, maybe 44s. Not sure, need some help.thank you and where to get them
    Roger
    • 6961
    Re: What are the right spark plugs
    Roger, I would say 44's would be fine, or even a 43 would work.
    • Wayne M.
      • March 1, 1980
      • 6414
      According to GM 1969 Engine tune-Up spec's, AC-R44 (std), or AC-R43 (cold).
        • 15706
        Spark plug heat range has been discussed a zillion times including this thread in the past week:
        https://www.forums.ncrs.org/showthre...-Running-rough!!!
        In particular, look at post #13.
          • 43297
          Wayne------
          Yup. All 1969 and later Corvettes originally used resistor-type spark plugs.
          • Roger D.
            • June 3, 2014
            • 180
            Wayne------Yup. All 1969 and later Corvettes originally used resistor-type spark plugs.
            Okay , I got it thank you everyone. I assume that most of the vendors have them like ZIP, Paragon, etc.
              • 43297
              Roger------
              It depends what you want. If you want plugs configured exactly as original, then you'll need to find some really old NOS plugs on eBay. They're not hard to find although they may be a little pricey.
              AC R43 and R45 plugs are still available from AC Delco or GM dealers
                • 15706
                You can buy a set of proper heat range AC plugs at just about any auto parts store, and they can cross reference the AC plug you specify to any other brand, or you can do it on the Web. All spark plug manufacturers have catalogs and cross reference charts on the Web.
