How to Adjust Air/Fuel Mixture 68 Carb? - NCRS Discussion Boards
  • Cathy S.
    • August 31, 2003
    • 293
    Just got my Quadrajet rebuilt. Adjustment procedure?
    • 15621
    Re: How to Adjust Air/Fuel Mixture 68 Carb?
    There is a step-by-step in the Chevrolet Chassis Service Manual. That and the Chevrolet Ov erhaul Manual are good books to have if one is going to work on their car.
    National Corvette Restorers Society! 1968-77 Corvette Chassis Service Manuals - The same manuals used by Chevrolet dealers! These cover ON-THE-VEHICLE maintenance, component repair, and removal and replacement of chassis components. They also cover mechanical specifications, electrical items, and the Corvette body. These manuals provide an ideal reference source for do-it-yourselfers. *The following Supplements require the 1974 Chassis Service Manual as a
      • 43259
      Cathy------
      If it's a quality rebuild, most of the adjustments should have been done by the rebuilder. You will probably have to finish-adjust idle mixture and idle speed, though. Follow the procedure found on your car's emissions label (driver side firewall).
      By the way, I've installed new Q-Jets and had them run PERFECTLY out of the box with absolutely no adjustments, at all.
      • Cathy S.
        • August 31, 2003
        • 293
        I have the service manual and have read it. I was hoping for some pointers?
        • Cathy S.
          • August 31, 2003
          • 293
          Cathy------
          Thank you Joe!
