L88 heads - NCRS Discussion Boards
L88 heads
  • Tony P.
    • December 11, 2008
    • 84
    L88 heads
    Someone has a set of L88 heads for sal,How can I tell if they are in fact off an L88
  • Keith B.
    • March 7, 2008
    • 928
    Re: L88 heads
    Whats the casting date?
    • Tony P.
      • December 11, 2008
      • 84
      Re: L88 heads
      3919842 are the casting #s
      • Patrick B.
        • August 31, 1985
        • 2002
        Re: L88 heads
        This casting number is for heads used on 68 and early 69 L-88s and and 68 and 69 L-89s. They were also sold in the parts department and probably most of the heads out there came from the parts dept rather than off a rare car.
        • Tony P.
          • December 11, 2008
          • 84
          Re: L88 heads
          He did say they were from a 68 L88. I was curious ,and thought the aluminum heads from Chevy back then went on all of the high horse power big blocks.
          • Edward B.
            • March 29, 2013
            • 691
            Re: L88 heads
            You'll need to get the dates on both heads to verify, but if they're from 1968, they were used from the factory on the following:
            1968 Corvette L88
            1968 Corvette L71/L89
            1968 Camaro L78/L89
            Ed
            • Tony P.
              • December 11, 2008
              • 84
              Re: L88 heads
              Thanks. I thought the same heads on a L88 were used on other cars from Chevy!!
              • Wayne M.
                • March 1, 1980
                • 6414
                Re: L88 heads
                Here's a pair of '842s' I have; dates shown below. Also, there's a gang stamp "AMB1167" on one end of each head. I assume the 11_67 is a date (Nov ? 1967).
                c
                a
                • Edward B.
                  • March 29, 2013
                  • 691
                  Re: L88 heads
                  AMB1167 is probably a rebuilder's code. (American Motor Builders??)
                  That and the HC at the upper right. (Hillary Clinton??)
                  My 842 heads are both dated 1-8-68 (January 8th, 1968) and I have no stamps like those on either head.
                  Ed
                  • Mark H.
                    • September 18, 2013
                    • 241
                    Re: L88 heads
                    More likely - "High Compression"
                    • Edward B.
                      • March 29, 2013
                      • 691
                      Re: L88 heads
                      You're probably right Mark, but I got a giggle picturing Hillary Clinton in a leather machinist's apron working on an aluminum head!!
                      Ed
                      • Tim G.
                        • March 1, 1990
                        • 1384
                        Re: L88 heads
                        1967 heads have don't have the temp sender in the head.
                        • Patrick B.
                          • August 31, 1985
                          • 2002
                          Re: L88 heads
                          Originally posted by Tim Gilmore (16887)
                          1967 heads have the temp sender in the head.
                          1968 842 heads and some late 67 392 heads have temp sender holes in the heads, but 67 manifolds have temp sender holes so most 67 heads do not.
                          • Tim G.
                            • March 1, 1990
                            • 1384
                            Re: L88 heads
                            Patrick, you're correct, that's what I meant to say. I edited my post.
                            • Ray K.
                              • July 31, 1985
                              • 375
                              Re: L88 heads
                              Wayne,
                              My set of "842" heads that I purchased new definitely have the " HC " letters stamped similar to yours.
                              Ray
