Hello everyone,
After reading many of the archived and older posts about the differences between early and late 1967 columns I'm still not 100% of what I have. My car is 05818 build early December 1966 and per latest judging guide I should have the early design. Looking at it and comparing to other pictures I found here, it looks like I have the second design - or missing/worn parts on the shaft. (I don't believe the spring in my photo should be exposed)
I believe the column to be original to the car (it's date stamped 339 6). Was there a recall on the first designed columns?
also, my rag joint has longer pins than in the the photo in the judging guide so I would appreciate learning more about my rag joint too. Maybe they changed the rag joint with the newer style column if there was a recall???
thanks for your help and for sharing the knowledge....
