Flint Small Block Castings - NCRS Discussion Boards
+ More Options
Posts
    • 15646
    Re: Flint Small Block Castings
    You are describing some serious choreography, Terry. I'd love to see a video......
    I am not aware of one, but I have never searched for it either. Closest I ever saw was a series of stills in a Hot Rod Magazine from the late '80s early '90s.
      • 15646
      • Mike E.
        • June 24, 2012
        • 920
        Jim -
        We tend to focus on V-8's, but there was a separate, but very similar world for the in-line six-cylinder engine, which was still very much a big player in passenger cars and trucks. They were also cast at Saginaw, trucked 24/7 to the old Flint Motor Plant down by the river in downtown Flint, and that plant produced several thousand L-6 engines every day for lots of passenger and truck plants. 1953 was a big year for the L-6 - it finally got full-pressure oiling to the rod bearings, and the old cast iron pistons were finally replaced by newfangled aluminum pistons.
        [ATTACH=CONFIG]53616[/ATTACH][ATTACH=CONFIG]53617[/ATTACH][ATTACH=CONFIG]53618[/ATTACH]
        Here's a cool video from 1936 showing the casting of the L6's. The Foundry portion starts at about 5 minutes into the video. Did foundry technology changed much in the 30 years after the film was shot?
        Mike
          Originally posted by Mike Eby (55078)
          Here a cool video from 1936 showing the casting of the L6's. The Foundry portion starts at about 5 minutes into the video. Did foundry technology changed much in the 30 years after the film was shot?
          Mike
          Mike -
          No, not by much, although the first automatic molding (pouring) lines were installed in the 60's, eliminating the manual pouring of 2900*F iron from ladles into molds. The sand and the iron are all gone now at Saginaw - all they use is aluminum, with the latest automated processes. It was the Saginaw Grey Iron Foundry in the 60's, and now it's Saginaw Metal Casting Operations, GM Powertrain.
            • 43295
            Mike -
            John------
            I believe the only gray iron foundries that GM still operates are the ones in Defiance, OH and Toluca, Mexico. GM also still has a nodular iron foundry in Defiance, OH.
            • Kenneth B.
              • August 31, 1984
              • 2091
              MIKE As JOHN said not much. The big difference is the way cores are made. In the old days sand with binders were blown in the core box & dumped on molded trays then baked in a oven to harden them. Today chemical binders such as Isocure are injected into the sand filled core box & the sand core comes out of the box hard. Tooling is now all CNC'D so castings are dimensionally better than making wood masters to make metal patterns & core boxes
