'68 window crank - NCRS Discussion Boards
'68 window crank
  • Brian W.
    • September 30, 1990
    • 216
    '68 window crank
    Which way should the window crank handle be facing when the side glass window is fully up and/or completely down. This is an early '68 if this matters. Thanks
  • Gene M.
    • April 1, 1985
    • 4233
    Re: '68 window crank
    Brian,
    I don't know if there is a "set" position for the cranks. I placed mine at forward down with the window up. That would be at 4 or 5 on LH and 7 or 8 on RH clock position. I do believe that the assembly line attempted to set them the same but that is just my opinion.
    • Brian W.
      • 216
      Thanks Gene
