69 side post battery cut off switch? - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    What's the best model to get for easy access with the limited side post access?
  • Jerome P.
    • October 22, 2006
    • 607
    Re: 69 side post battery cut off switch?
    Don I got my cut-off from Corvette Central. It works great in my '72.
    • Chuck G.
      • May 31, 1982
      • 2036
      I had one of the WirthCo knife switches in my 69. Worked well. I liked it much better than the green wheel.
      Chuck
      • Gary H.
        • June 8, 2008
        • 308
        When properly installed, the posts on a side post battery are almost directly under the front part of the frame, so you might not have enough room for a blade type disconnect. I use one like this on my car with no issues. Easy to get your fingers around the knob even though you can't really see it.
        • Bill C.
          • July 15, 2007
          • 904
          luckily that R79S battery mess was only late 69 production. When they swapped to the R89S/W the posts were on the other side of the box and you can use a quick disconnect there with no issues.
          I finally decided to unbolt the NEG battery cable from the frame rail. It turned out being easier and less damaging to my knuckles then messing with the quick disconnect.
          • Lawrence M.
            • February 1, 1995
            • 404
            Hi Don,
            I bought mine from Restoration Battery. They run an ad in the driveline. It is the knob type. Mounting the blade type on a late 69 with forward facing side terminals would be difficult if not impossible. Be sure to mount it on the negative post.
            Larry
            2002 Z51 Convertible
            1969 L46 Convertible
