Jim Lockwood (2750) --Thanks! - NCRS Discussion Boards
  • Rob V.
    • July 31, 2002
    • 261
    Hi Jim--After reading your response to my question last evening regarding sealer for intake manifold bolt threads, I went out into the garage and found an unopened tube of Permatex #2. I removed the errant bolt; cleaned it with brake cleaner; and reinstalled it. Ay noon today I took the car out for a drive, (in the heat--outside air temperature around 88 degrees); ran it on the freeway at 70 to 80 mph; then surface streets, and back roads, with two stops ( engine shutdowns) over 30 minutes each time. Upon my return home, not a drop of oil had leaked out. Previously, there would have been a teaspoon of oil outside that intake manifold bolt. Just wanted to let you know that the leak was fixed thanks to your recommendation.Thanks again! Rob Vanderhoeven
    Rob
    SPEAK YOUR MIND, but ride a fast horse. -- Anonymous
  • Jim L.
    • September 30, 1979
    • 1817
    Re: Jim Lockwood (2750) --Thanks!
    Glad that worked well for you, Rob.
    Jim
