Water pump stud/bolt - NCRS Discussion Boards
  • Roger D.
    • June 3, 2014
    • 180
    JUST RECEIVED THE STUD/BOLT FOR THE WATER PUMP THAT HOLDS THE ALTERNATOR ADJUSTING BRACKET. THE STUD AND ZINC BOLT ARE ORANGE. WHAT ABOUT THE HEAD PAINTED BETWEEN THE WATER PUMP AND BRACKET. ORANGE OR UNPAINTED.THANK YOU R
  • Edward J.
    • September 15, 2008
    • 6940
    Re: Water pump stud/bolt
    Roger that bolt w/stud would have been black phosphate finish from factory, I believe as all the pump bolts on my 72 are black phos. , and that Bolt on w/pump was left un painted. As it goes the factory remove and replaced the painted bolts that have brackets attached to them, So being the alternator bracket is attach to w/pump ,it should have no paint.
    • Roger D.
      • June 3, 2014
      • 180
      Edward so I understand. in 69 should all the water pump bolts be orange and just that head between the bracket left unpainted, or is everything black except for the bolt between the bracket. Sorry I am a little slow.
        • November 30, 1989
        • 11602
        I would suggest that everything you show as zinc in your photo should be black phosphate.
        I believe this would include the zinc bolts you show as holding on the power steering bracket.
        There were few, if any, zinc bolts used on your engine.
        • Roger D.
          • June 3, 2014
          • 180
          Okay it seems that there may be 2 answers 1 all black and one all black except for the zinc bolt to the pump. Very surprised it was not orange but I do understand now.Thank You GentlemanRoger
