63 A/C help - NCRS Discussion Boards
63 A/C help
  • Harry S.
    • July 31, 2002
    • 5349
    63 A/C help
    My brain is stuck it needs help.
    Last summer I had a high pressure problem with the A/C. It was so bad it blew the hose off the input side of the condenser. I determined that the expansion valve was jammed shut and the STV needed a rebuild. To be safe, I replaced the expansion valve, installed an STV bypass and replaced the dryer.
    It got hot enough here today to turn the A/C on so I did. I made it about two (2) miles and the same hose blew off. It has to be a high pressure problem, but where. I know anything is possible but can the evaporator or the compressor clog and cause the pressure problem. I'm using 134 at the moment.
    Hot and sweaty!
  • Edward J.
    • September 15, 2008
    • 6961
    Re: 63 A/C help
    Harry, On the line that the hose blew off on does it have a barbed fitting?
    • Harry S.
      • July 31, 2002
      • 5349
      Re: 63 A/C help
      If you mean the hose clamp with the extension that hangs over the line and, yes, it's there.
      • Edward J.
        • 6961
        Re: 63 A/C help
        Harry, the barbed end is a edge on the metal line that holds the hose from slipping. If you can take a pic. and send to my I-phone. I will let you know.
        • Harry S.
          • July 31, 2002
          • 5349
          Re: 63 A/C help
          On their way!
          • Harry S.
            • July 31, 2002
            • 5349
            Re: 63 A/C help
            After consulting with Ed, I have an incorrect high pressure side aluminum tube leading to the condenser. There are essentially no barbs in the one I have and it will not hold the high pressure on a hot day. I'll look for a new fitting and a new freon line. This should fix the problem.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11370
              Re: 63 A/C help
              Harry, It's nice when you get a definite solution, and a relatively simple one it sounds.
              Glad you found the problem. Good thing you've been using R134A !!! I just had to re-R12 the wife's '72 Jag. Yike's that's expensive stuff.
              Is that a special GM only fitting, or can you get something locally?
              • Harry S.
                • July 31, 2002
                • 5349
                Re: 63 A/C help
                Thanks, the part is available from Old Air Parts for $32.00.
                • Joe R.
                  • July 31, 1976
                  • 4552
                  Re: 63 A/C help
                  Harry,
                  Sorry about your run of bad luck. First a Tonawanda block and now an Old Air Products Hang on AC unit!
                  Maybe you should consider Barrett-Jackson in January instead of golf in Florida.
                  JR
                  • Harry S.
                    • July 31, 2002
                    • 5349
                    Re: 63 A/C help
                    I ordered the aluminum tube so all set there. I need to also replace the associated high pressure rubber hose as it was nicked when it blew off and I'm sure the inside is scored.
                    Anyone have a source for a single hose with the correct lettering? I really don't want to send LIC $125.00 plus shipping for a set!
                    • Harry S.
                      • July 31, 2002
                      • 5349
                      Re: 63 A/C help
                      Does anyone have the specifications for fan belt 3840397? It's the A/C belt.
                      • Edward J.
                        • 6961
                        Re: 63 A/C help
                        Harry, corvette central list it as 57"
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11370
                          Re: 63 A/C help
                          Yes......
                          15/32 x 57 according to the P&A 31 Truck catalog....HERE
                          THIS says it changed to 3888404 in Oct 1968.
                          • Harry S.
                            • July 31, 2002
                            • 5349
                            Re: 63 A/C help
                            Yes......
                            Well 57" just doesn't fit. I'll start looking into pulley sizes.
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11370
                              Re: 63 A/C help
                              Argh, and you thought belts were confusing? I hate pulleys. Especially when there's no good list of specs anywhere.
