65 BB with F40 - NCRS Discussion Boards
65 BB with F40
  • Bill W.
    • March 1, 1980
    • 2000
    65 BB with F40
    A friend told me that a 65 BB with F40 has a different lower rear shock mount than a standard lower shock mount . I looked in my assembly manual and didn't find anything . I have never heard of this does anyone know about F40 or F41 .
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 BB with F40
    Bill -- IMHO, the friend is correct; the 1965 F40 H.D. suspension (whether on F.I. or 396) should have a lower shock mount/strut rod retainer shaft (Gr 5.381, #'s 3829265 and ...66), according to my '65 P&A30, Rev 1 July.
    IIRC, these do not have the angle that the standard suspension shafts have.
    The 5th ed. 1965 TIM&JG does not mention this, and the AIM is useless for F40 (instructions to install same as regular suspension, or even worse, that L78 rear suspension installs same as F40).
      • 43202
      Re: 65 BB with F40
      Bill------
      Yes, the shock mount shafts were different for standard suspension and F-40/F-41.
      The standard suspension used shafts GM #3820929 and 3820930. These were the part numbers and the forging numbers seen on the un-machined portion of the shaft.
      The F-40/F-41 shafts were GM #3829265 and 3829266. Both of these were machined from the same forging and the un-machined portion of the shaft of original shafts will show 3829265-66.
      As far as I know, the 3820929 and 3820930 shafts were used in PRODUCTION on all standard suspension Corvettes from 1963 to 1982. However, the 3820929 was discontinued from SERVICE in February, 1978 and replaced by the 3829265. The 3820930 was discontinued from SERVICE in July, 1978 and replaced by the 3829266.
      Later SERVICE examples of the 3829265 and 3829266 do not have the forging numbers embossed on them. Instead, they have either laser printing of the part numbers or nothing, at all.
      I have NOS examples of all of the above but I'm too lazy right now to go out and get them to photograph. However, attached is a photo of an NOS example of one of the standard suspension shafts.
      • Bill W.
        • March 1, 1980
        • 2000
        Re: 65 BB with F40
        Thanks Wayne & Joe .
        • Tony S.
          NCRS Vice President, Director Region VII & 10
          • April 30, 1981
          • 982
          Re: 65 BB with F40
          Bill, here are a couple of photos of the '65 F40 shock mounts that will be used in the upcoming 6th edition of the new '65 JG.
          Tony
          Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
          Original member of the Kansas City Chapter, est'd 07/11/1982.
          Member: 1965 and 1966 National Judging Teams
          Judging Chairman--Kansas City Chapter.
          Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
            • 15638
            Re: 65 BB with F40
            What are the actual geometric differences between these two parts?
            From the above photo of the base and HD parts it appears that the base suspension part has a longer distance between the shock mount shaft axis and the shoulder of the strut mount shaft, and the HD part appears to have a slightly larger diameter shock mount, but maybe these observations are just optical illusions.
              • 15582
              Re: 65 BB with F40
              Duke,
              The difference is in the angle between the two shafts. The more open angle allows greater clearance for the larger diameter of the HD shock. This "feature" is most obvious on cars with side mounted exhaust as the lower shock mount(s) are visible from the rear and the greater angle is immediately obvious.
              • Wayne M.
                • March 1, 1980
                • 6414
                Re: 65 BB with F40
                Below big pic is a thumbnail view of std. susp. shafts that shows the slight difference in angle. Same ones as in big pic.
                a
                • R N.
                  • May 31, 2002
                  • 640
                  Re: 65 BB with F40
                  Duke,
                  Terry et al,
                  Would this this mean that the HD shock would not work on or fit a standard lower shock mount?
                    • 43202
                    Re: 65 BB with F40
                    Originally posted by R. Kurt Neiman (38038)
                    Terry et al,
                    Kurt------
                    Actually, the HD shocks will work with the standard mounts (in fact, Edward's situation also proves the point since I fully expect this non-HD shaft has been on the car since new).
                    I've never figured out why GM felt it was necessary to have a different shaft for the HD suspension UNLESS there was some other difference between the shafts (e.g. material, heat treat, etc.)
                    • Bill M.
                      • April 1, 1977
                      • 1386
                      Re: 65 BB with F40
                      Kurt------
                      Joe:
                      It may work in real life but might not on paper...? There are rigid clearance requirements that must be met to release a part for production.
                      Bill
                      • Jimmy G.
                        • November 1, 1979
                        • 976
                        Re: 65 BB with F40
                        Question It is said that in a revision dated 7/1/65 that the shock mount changed for F41 So I assume a car made earlier will have standard shock mounts Reason being I have a fairly original 65 396 with F41 and it has standard mounts and it was built prior to 7/1/65 Any comments ??
                        • Bill W.
                          • March 1, 1980
                          • 2000
                          Re: 65 BB with F40
                          Hi Jimmy . My non F40 396 was built May 65 and has first design mounts . What is the vin on your 396 ?
                          • Jimmy G.
                            • November 1, 1979
                            • 976
                            Re: 65 BB with F40
                            Serial number is 200xx
                              • 43202
                              Re: 65 BB with F40
                              Jimmy------
                              Where is this revision found?
                              In any event, the two different sets of shock mount shafts were specified in SERVICE as early as 1963 and both sets of part numbers are consistent with a 1963 release.
                              Is it possible that some F-40/F-41 cars were originally built with the standard shafts? Of course. I would expect this would have been an easy mistake for the assembly plant to make. However, I think that the different sets of shafts were always specified by GM for standard and F-40/F-41.
